Old 02-04-2020, 05:47 PM   #1
thstone
Originally Posted by Jgkram View Post
What I can’t get my head around is the process from that point. I cannot see how he got to his filled (gray) part from his initial taped up foam start.
The second post in the thread...
... start off by filling the (foam) voids with bondo, sand and shape back to smooth and then begin the process of laying glass over the foam.
From what is seen in your pictures, you appear to be very close to a final size you are wanting to end with. This will be a problem as you lay glass and resin you will build up a considerable thickness. You should consider giving yourself at least 1/8 to 3/16 of an inch of room for glass build up and then final sanding and finishing.
