Old 01-21-2020, 07:56 PM   #10
Qingdao
Qingdao's Avatar
Well I hit a brick wall. Kennedy doesn't make an adaptor for a 4.3 with an aluminum oil pan for a 5 speed boxster. They wrote me and said something about the starter not having a place with the adaptor plate.
Ah poooo.
I messaged them back to see if I could use an 88-95 4.3 engine. I mean if its the aluminum oil pan that's in the way I can work around that. Shoot mild steel is easy to work with.
I don't see the difference between a 4.3 and a SBC and the difference between the LS and SBC is .400" of bellhousing spacing. So buy an LS adaptor and add .400" of spacing???
One question I do have for any high output boxsters out there; what clutch's are yall running? I'm not seeing too many aftermarket options out there. How much power can the stock clutch hold?
'98 PP13B powered "RX986"
