Old 01-18-2020, 09:07 AM   #17
Russdawg1
Ok..... so...... this comment just changed everything, as far as I'm concerned. ;-)
If you mentioned before that you planned to track it I missed it.
I track mine..... and that's where I've incurred costs that can't be considered into the regular maintenance / repair calculator. I've broken stuff.... a lot of stuff, at the track. It's been expensive. TOO expensive. But to be very clear: I'm not just driving around out there. I push it hard, I use the tiger teeth at apex or corner exits sometimes, and I find redline regularly. I'm going to work this season on doing LESS of that.... because it's expensive. Haha
And to keep the record clear in spite of recent rants: I think the Porsche boxster IS more difficult, and costly, to own, maintain, and to DIY on, than just about any other car. (This is car #74 for me, or#76 or something, I forget)
Most (or many) seem to disagree with me. Im not at all sure why mr. 7-car has lumped me as the direction of his current tantrum, because he and I actually agree that this car IS, and WILL BE more expensive to own and maintain than most. And I've personally spent MUCH, MUCH more than $2k/yr in the 2 years I've owned it. Much more. But I attribute MOST of that to track breakage and upgrades / mods for the track.
Now what I HAVE said, is that if you don't DIY then don't buy a 20 yr-old Porsche. And I've implied (or maybe actually stated) that if you DIY, the car can be affordable.
And yes.... I post from my phone.... because when I'm sitting at a computer it's because I'm working. Again..... I'm not at all sure why that's offensive to anyone. (Well.... maybe because sometimes when I post from my phone I do it from the porcelain throne! ::gasp:: Haha)
Sent from my SM-G970U using Tapatalk just to provoke mr. Nicecar.
It was sort of a joke, sort of not.
I’ve always dreamed of having a cool track/rally car. Dual usage obviously. So I can’t be ripping out the HVAC for even more weight loss.
It’s a goal that I’ve set for after I’ve purchased the Boxster and settled it down to a point that maintenance is now just oil changes and replacing things that wear out naturally over time. I would likely take driving classes in parallel with this time, and then combine the two once done. Well maintained Boxster, and newfound driving skills!
If there’s an option for having two, one for both situations, that may be where I achieve my true, swapped track car from a roller
Russdawg1 is offline   Reply With Quote
