Old 01-09-2020, 12:07 PM   #1
PorschePR
did you got it fixed?
I have the same issue with my 3.6L 911 (cylinders 4,5,6). I have change done: coils, spark plugs, 3 smoke test, evaporative valve, flush each fuel injector, Cam shaft sensor, Crank shaft Sensor, knock sensor, clean throttle body, new MAF. This is so frustrating. I will do a compression test this weekend to see the values.
sounds like the engine will come down eventually.
PorschePR is offline   Reply With Quote
