Old 01-07-2020, 12:59 PM   #1
petropolis
There is one more wire you need to connect. The Porsche uses a powered antenna and if you don't power the antenna then you'll get bad FM reception and no AM reception. To power the antenna, you'll have to connect a wire from the switched wire on your stereo to a white wire on the same connector that has the power for your amplifier. This document lists the power wire.
petropolis is offline   Reply With Quote
