Old 10-14-2006, 12:04 AM   #2
SD987
Rail26 provides a nice summary, but off the top of my head, I'd say the specific differences between the two engines are:
* 987 crankcase has a fully aluminum bearing saddle for a reduction in weight vs the 986 which has cast iron inserts
* 987 crankcase has a deeper central hole for a .7 lb reduction in weight
* The tensioning rollers and deflection pulleys in the 987 belt drive are made of plastic in engines with a manual gearbox while the 986 are made of steel
* 987 has a new air cleaner with new housing
* 987 resonance intake system has a twin-branch distribution pipe with intake-manifold flap
* The electric fans in the engine compartment of the 987 are infinitely adjustable where the 986 fans are two-stage
* 987 exhaust sytem has lower gas back pressure due to larger cross sections and damping of drive-related vibrations by heat-resistant damping elements among other things
* 987 standard manifold is lighter
* 986 3-way catalytic converter has one converter left and right, where the 987 has one pre- and one main catalytic converter left and right (the lightest catalytic converters in the world)
* 987 silencer is lighter with improved flow rate; and 2 parallel silencers with crossover pipe and integrated main catalytic converter
* 987 water pump has an optimised impeller for increased flow rate and improved component cooling
* 987 water bearing casing is plastic and flow-optimised, where the 986 is die-cast aluminum and 1.9 lbs. heavier
* 987 tandem pump has a vacuum for brake boosting provided by a mechanical vacuum pump where the 986 has a sucking jet pump and vacuum reservoir
* 987 oil extraction pump has lower frictional losses and higher delivery capacity
* 987 doesn't have an oil dipstick (which saves .39 lbs(
* 987 radiator air flow is closed, directing air to the front wheel housings where the 986 is open, directing air in front of the wheel housings
* 987 radiator fan control is continuous, where the 986 is two-stage
* 987 engine compartment scavenging blower is dependent on intake air and ambient air temperature, where the 986 is dependent on intake air only
* 987 secondary air pump is fastened directly to the engine where the pump in the 986 is fastened to the body
* The 987 generator cranks out 420 more w (2100 to 1680)
* The 987 uses motronic 7.8/40 DME which has enhanced computing and memory capacity
* 987 engine weighs about 10lbs less in manual and 12 lbs less in auto but produces 12 more hp, 7 lbft more torque with a 3kW increase in specific output
That's all that comes to mind, but if I thought about it for awhile I might come up with a few more differences.
http://i7.tinypic.com/24ovngk.jpghttp://i7.tinypic.com/24ow0id.jpg
06 987S- Sold
Carrara White / Black / Black/Stone Grey Two-tone
05 987 5-speed - Sold
Midnight Blue Metallic / Metropol Blue / Sand Beige
06 MB SLK350- Lease escapee
Iridium Silver Metallic / Black
We've heard that a million monkeys at a million keyboards could produce the complete works of Shakespeare; now, thanks to the Internet, we know that is not true. - Robert Wilensky
SD987 is offline   Reply With Quote
