Old 12-28-2019, 11:30 AM   #3
NewArt
Artist, 986S tinkerer
NewArt's Avatar
So... the questions are begged... and I submit them to the PROS on this forum:
If you're running a 2.5... can you swap the manifolds from a different engine to run the two tubes (from one)?
If affirmative... is there any improvement in performance?
I do see on the two-tuber that the throttle body slightly is offset... and that could pose a problem with the 2.5 throttle body angle.
Thank you, and Cheers!
There’s also the problem of the throttle cable vs electronic
