Old 12-21-2019, 09:17 PM   #1
Javi Cooper
Originally Posted by Oldcarguy View Post
Hi Javi, yes your org pic is the complete aerokit 2 package. If you locate a set you’ll also need to get the underbody clips to attach the lower edge. I have the clip part number around somewhere. Let me know if you need it.
I tried two different sets of fiberglass replicas (techart and hofele copies) before deciding to go with used oem aerokit 1. No comparison for fit and finish between the oem polyurethane skirts vs the fiberglass copies.
The aerokit 2 fairs better as takeoffs than the aerokit 1 because of the way the aerokit 1 attaches to the car (really meant to be permanent while aerokit 2 uses two sided tape on the upper edge).
Good luck with your search!
Thank you so much for the info. Fit and finish from OEM is what I'm going after (from previous experience with other cars). Couple of questions:
I have the OEM Aero Kit 1 side skits on my car (tape is coming undone, and they don't match my aero kit 2 bumper IMO). Can I use the same clips to attach the aero kit 2 skirts underneath? Are the holes in the same location?
You mention that the 2 use double-sided tape while the 1 (which I have) is a permanent install. Does this mean I can't take them off? If I do, will there be any exposed extra holes somewhere?
Thanks again
Javi Cooper is offline   Reply With Quote
