Thread: Stuck bolt
Old 12-12-2019, 05:23 PM   #4
blue62
you say it came part way out then locked up.????
I wonder if it is cross threaded?
If you can turn it in- try working it in and out with the acetone -ATF concoction I mentioned. When you use it let set for half hour or so after you put it on the bolt before you try to get it out.
blue62 is offline   Reply With Quote
