Old 12-12-2019, 08:44 AM   #1
Gilles
Originally Posted by Racer Boy View Post
It's either a CV joint, driveshaft, or clutch. It's possible that the transmission broke, but not likely.
The CV joint came to mind first but if the clutch pedal feels iffy could be a broken fork (throw out bearing) as well.
The CV joint is very easy to check (visually) but the fork it's a bit more complicated as you will have to remove the gearbox..
