Old 12-08-2019, 06:13 PM   #1
blue62
Originally Posted by 100percent View Post
Yes, I should have added more details. There was power, but turning the key produced nothing. However, it is still good to know about possible battery problems, should something happen in the future.
After I posted, I thought about how the clutch needs to be pressed in order to start. So, it's also good to know about clutch related problems.
Thanks guys.
Well with that info:
Do the checks I mentioned previously.
Check the condition of the clutch safety switch. As mentioned by 78F350
Go on youtube and find a video on how to do a voltage drop test on your starter system.
A Relatively simple test but a visual of it will do better then I can describe it.
A voltage drop test on the starter system will tell you if you have any problems or potential problems with the starter or its related wiring.
