Old 11-27-2019, 08:52 AM   #1
Gilles
In what manner are they failing? you used the word "pop"?
One time on a recently installed gearbox the slave wen't "pop" and the pedal went to the floor getting the brand new clutch disc completely wet on hydraulic fluid...
It seems that I failed to fully seat the 'plunger' from the slave into the cavity of the fork and as soon as I pushed the pedal it went down..a real mess and everything had to come apart again.
But if you managed to drive a few miles before the failure occur then most likely you got NOS (new old stock) slave that had dried rubber seals that failed under pressure.. that would be my guess
Gilles is offline   Reply With Quote
