Old 11-18-2019, 08:40 PM   #4
Gilles
I'm running -3 front with zero toe and rear -2.2 with 1.5mm toe in per side in rear, measured over a 15" span.
Steve,
After lowering the subframe to install a front GT3 bar, and decided to do another alignment, again, using with your measurements as I liked the way the car felt.
However, after re-reading your post, t you used 1.5mm toe-in on the rear wheels 'measured over a 15" span'
The question is: What would be my true toe if I measured 1.5mm of toe-in at 20" ..? (my car has 20" wheels)
The curiosity killed the cat ..ha
