Old 11-12-2019, 03:19 PM   #3
Escy
Thread Bump!
I'm looking into this at the moment. The 5 speed shafts fit inside the 6 speed hubs but the issue is the diameter of the axle is about 10mm smaller on the 5 speed where the ABS ring is. This means there is a gap between the ABS sensor and the axle. If you could find an ABS sensor with a longer body I think it would be a straight swap
Escy is offline   Reply With Quote
