Old 10-30-2019, 12:48 PM   #10
Brian in Tucson
Originally Posted by Blue99 View Post
Hi you never ‘ top up ‘ a system. You take out all remaining gas , vacuum the system to remove moisture then refill with the correct weight of gas in grams ~as in 750g etc.
If moisture is not removed it can freeze at the very least causing a restriction
Most of these cans cost £45-50 most indys will do a proper job for that money
Moisture is really bad for seals and o-rings, too.:troll:
2001 Boxster
2007 Toyota Highlander
