Old 10-30-2019, 07:54 AM   #1
Vtx531
Harbor Freight sells an AC kit for $50 and a vacuum pump for $150. Recharging or adding Freon with the kit is very easy
Autozone rents both for free. Make sure you change the oil in the rental unit with fresh vacuum pump oil because moisture gets in the oil over time and affects the amount of vacuum that can b pulled out of the system.
Vtx531 is offline   Reply With Quote
