Old 10-17-2019, 01:15 PM   #10
blue62
Originally Posted by bg305 View Post
Thank you!
I ordered one from Pelican yesterday, should arrive tomorrow. I have the car up on stands already and dumped the oil and cleaned the MAF.
Do you think the failing separator could have caused the loss of power though? I have not seen much discussion on that. I am worried i will get it all back together and still have an issue... Will know soon enough.
With the failure of your AOS and the resulting oil in your intake my guess (and it is only a guess) is that oil mist has had an ill affect on your MAF sensor. Cleaning them with a good MAF cleaner will "sometimes" fix the problem. They are actually very sensitive to very fine dirt and oil particles. so it may need replaced even if fairly new.
The MAF can be tested with a multimeter but I don't know the values that you need to see.
