Old 10-01-2019, 01:00 PM   #2
Lowski
I just did my 99 with traction control without messing with the ABS or TC valves. Everything works fine.
If you are buying a new Motive power bleeder make sure you check that it works before you start. The new one I bought had a blockage in the suction tube that goes into the reservoir. I ended up having to cut the hose clamp off and use a small drill bit to clean out the tube. Of course I found the blockage once the car was in the air on jack stands ready to go and after I had put fluid in the tank.
I emailed Motive about the issue and never heard a peep out of them. I would have sent it back for warranty if I hadn't already had the car ready to go for it's fluid change. I didn't want to button everything up and start over again weeks later.
The product works well, but I'm a bit bitter they ignored me completely.
Lowski is offline   Reply With Quote
