Old 09-28-2019, 09:07 AM   #13
BYprodriver
BYprodriver's Avatar
Originally Posted by jaimster View Post
guys I m not able to tighten the plug at all it feels as the treads are loose always !!.
has any body ever heard of ECO plug ? if so what are your thoughts on it
as far as getting a used sump plate I could - last resource new gaskets kits too its adding up...
work done or process of getting it : replaced spark plugs , all filters including fuel filter and big One process of replacing the top !!
rear window was messed up it is a job to say the least !
The good news is when you buy a Boxster one of the 1st things you should do is remove the sump plate to see what is in there. You should buy a LN magnetic drain plug for it to. I have a extra sump plate for sale too.
