Old 09-21-2019, 04:32 AM   #10
BertoneP
There should be no play whatsoever where the struts attach. Neither to the body nor to the suspension.
So this play I believe is the reason for the clonking noise.....if so, drilling a bigger hole in the fittings of the fork arms and inserting a thinn metal sleeve so there is no play between arm and stud, could be a cheap solution to the problem. The trw arms are 70 EUR each approx.
What do you think
BertoneP is offline   Reply With Quote
