Old 09-20-2019, 01:25 PM   #1
piper6909
piper6909's Avatar
Originally Posted by BertoneP View Post
Can anyone confirm that there should be a little play between the studs and the holes were the studs slide into on the suspension arms? Or should it be a tight fit? I.e. no metal to metal noise if you wiggle the stud when in the arm hole....
There should be no play whatsoever where the struts attach. Neither to the body nor to the suspension.
piper6909 is online now   Reply With Quote
