Old 10-09-2006, 04:28 PM   #1
KRZTACO
I can't confirm...however if anything you can still put your new pads on and re-use the brake hardware. Be sure to lube the hell out of the hardware with the anti seize stuff, and don't be afraid to use the anti-squeel stuff on the backing of the pads.
Last thing...goto Sears and pick up a brake pad spreader. Tt looks like a metal backing pad with a twisty knob.
This will save you a **************** load of time and is worth the $9.99
Good luck!
KRZ
http://x402.putfile.com/2/5800280187-thumb.jpg
Voghtland 30-50mm Coilovers
19x8.5 x 19x10 Forgline rims
Magnaflow Exhaust
KRZTACO is offline   Reply With Quote
