Old 09-11-2019, 08:37 AM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
What I would do is pull up the pinout diagram for the current radio, and the radio you want to install, and compare them. That will help you determine what each wire is as it is currently setup, and where the wires should be for the radio you want to install. For a Becker headunit the diagram is in the manual.
