Old 09-10-2019, 08:16 PM   #10
blue62
Originally Posted by Renos View Post
Coil packs look brand new. In fact I noticed they are the updated coils with the thicker mounting holes and longer bolts.
I have a fuel pump coming in and the tube I mentioned had a leak, as well as the voltage regulator. I am still curious about the condition of my aos given I had some oil in the intake but didnt seem like much.
I could go ahead and try for another maf while at it. I will try to have the wife get these tests done given I can't do a thing for a month.
I did replace a fuel cap because of cracked seal and I guess it got my emission leak out but I still also worry about that fuel smell. I wonder if I have a combination of problems going on. Maybe the regeneration valve is failing or crank position sensor. Very confusion with this issue.
All I know is car running lean under acceleration and the crank issue is a major concern. I also noticed since we got the car that I have rpm hunt / bouncing in 4th and 5th gear from 1400 to 2200 rpm. Pretty often too. I would say every second or maybe 1.5 times a second. It jumps up maybe 100 rpm and back. Dunno if this is another contributing symptom but as easy as this car is to work on, it sure is complicated compared to my 2008 mazda mx5.
Yes you could have multiple problems going on. Things like lean under acceleration, RPM hunt, point to a vacuum leak. that would be my first place to look. second would be a lazy (slow) signal from the primary O2 sensors.
My method of diagnosing problems is to start with the simplest most basic things first, proof them out as positive (with no doubts) then move to the next thing on the complexity ladder.
Problems like yours always start by just looking in the engine bay with a flashlight for about a half an hour not even touching anything just looking for things out of place.
Like wiring that could be rubbing against metal or a cracked vacuum hose or?????
Second thing I do is a vacuum test it can tell you a lot if you know what your looking at with the reading and how the needle is acting.
Depending on what my vacuum test tells me that dictates my next step. I don't replace things like MAF sensors or any cam sensors or any sensor unless I know it is faulty. (It could be just faulty wiring attached to it). if there is faulty wiring most wiring problems are due to bad grounds.
So a long winded way of saying simplest things first go step by step up the ladder simplest to most complex.
Most problems are not very far up the ladder.
