Old 09-01-2019, 05:58 PM   #1
JimmyBad
01 Basalt Metallic 986
JimmyBad's Avatar
Well Hope I'm wrong, but the pre cat 02 sensor on the 3.2L cars is on the header ahead of the convertor. So the mid pipes would only have the after cat 02 sensor, where the 2.5L cars have the pre and post 02 sensors on the mid pipes. Hoping to find the 2.5L pipes so I don't have to modify. Might have to sometime but that's why I'm starting the search early! Of course I may be wrong.
The manifold that I have from the 2.7l has bungs for both pre and post o2 sensors. I don't think I have any o2 sensors plugged into the mid-pipes. Your setup might be different as you may have both pre and post o2 sensor on your mid-pipes like you've said. I'm not sure if your manifold is monitored but it seems like you're looking for 2.5l mid-pipes anyways, similar to the picture below.
JimmyBad is offline   Reply With Quote
