Old 08-28-2019, 06:48 AM   #1
Silber
Little bit of follow up, thanks for the tip on the vacuum leak, did some research and it turns out you can check for a vacuum leak with Durametric by looking at MAF values.
At idle MAF should be 10 to 15. If you have a vacuum leak it will be lower. My MAF value is actually higher, 25 to 27 at idle spiking to 90 if any throttle movement.
So, it looks like the MAF sensor actually is bad. A vacuum leak would’ve showed a lower number.
MAF arrives tomorrow, we’ll see if that fixes it.
Silber
2002 Boxster S - Silver/Boxster Red
Coilovers - LSD - CAI - High Flow exh. - F&R Adjustable Sways
LN 3.2 to 3.8 - parts acquired, pending assembly and tuning
Silber is offline   Reply With Quote
