Old 08-27-2019, 05:02 PM   #1
blue62
Originally Posted by Fiddlebog View Post
if you take your door panel off an GENTLY peel back the foam sheet underneath, you will see some adjusters in the window mechanism for the window heights. (purple arrows)
You don.t have to take the door panel off.
You can access those adjusters from the bottom of the door.
There should be rubber plugs covering the access holes.
