Thread: Oil Pressure
Old 10-08-2006, 10:20 AM   #2
MNBoxster
Originally Posted by HOUSTONBOXT
Just Been Out For A Drive And Noticed That The Engine Oil Pressure Warning Light Is Blinking On And Off When The Engine Is Idling. Soon As I Rev Up, Light Goes Off. Car Is A 2000 Boxster With 54,000 Miles. Anybody Had This Problem ?
Hi,
I assume you mean the idiot light? Well, if it's blinking, it indicates that the Oil Pressure is low. Have you checked the Oil level?
If it's the Oil Display which is blinking, this too indicates a low Oil levelif the MIN bar is flashing. If the entire display is flashing, it indicates a fault in the Oil level detection system such as a short to ground, loose connector or broken wire.
If the Oil level checks out OK, then you may have issues with the Oil Pump. Hope this helps...
Happy Motoring!... Jim'99
