Old 08-25-2019, 08:34 AM   #6
Zzorro
Zzorro's Avatar
I was having a similar issue. I'd get Sudden loss of power, the engine bogs down, pushing on the accelerator just makes the car want to stall. I'd push in the clutch, let it idle/coast a bit. Engine would not stall, just idle. Then it would seem to sort itself out. I'd engage the clutch (geared down to accommodate the loss of speed) and I would get back full power. Episodes would last maybe 30 seconds or so. There would be no check engine light. The only other contributing factor would be that it seemed to happen after the car had been sitting for a while (2-3 weeks) and engine was just warming up. I already replaced the MAF (which solved CEL and other performance issues). I always use premium fuel as well. I have 170k kms on the dial.
After hunting around on the forum, I opted to change the fuel filter and fuel pump because it appeared to be a fuel delivery problem. We will see how that plays out.
Are your symptoms similar to mine (minus the manual trans)?.
98 Boxster - Ocean Blue metallic. Bringing it back to life and having fun doing it!
20 Harley Streetbob -
Zzorro is offline   Reply With Quote
