Old 08-25-2019, 06:10 AM   #3
Ciao
Ciao's Avatar
Originally Posted by 1PorscheBoxster986 View Post
There should be no difference. Make sure your car is on a flat surface and your car is cold when you check it with the dipstick. It can take some time for all the oil to go back into the sump because it holds 9 quarts. Do not rely on the digital oil reader if it reads low. I have seen my car go down to one bar above the minimum line on long drives. It is/can be very inaccurate.
At the current reading of the oil dipstick; it was sitting in the garage for a day, or overnight, flat, level surface, the digital display shows a notch or two low, but the dipstick oil level shows inconsistencies from one side to the next. Either way the oil level is not at the lowest notch where it would need oil, but in the middle on one side and turn over the dipstick, the level is just below the top notch on the other side.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
