There should be no difference. Make sure your car is on a flat surface and your car is cold when you check it with the dipstick. It can take some time for all the oil to go back into the sump because it holds 9 quarts. Do not rely on the digital oil reader if it reads low. I have seen my car go down to one bar above the minimum line on long drives. It is/can be very inaccurate.
