Thread: Rear Thump
Old 08-22-2019, 04:35 PM   #7
piper6909
piper6909's Avatar
The sad part is that with the LCA bushings and the Center Motor Mount, you can't tell if they're bad until you removed them.
My money is still on the LCAs I mentioned on my prior post. I had the same noise where I couldn't tell if it was suspension or the convertible top frame. I did some research and found that they were common culprits so I changed them and noise gone! Although now I'm starting to get some noise from the fronts...
piper6909 is online now   Reply With Quote
