Old 08-22-2019, 01:27 PM   #18
particlewave
Originally Posted by A8ked View Post
Have you checked the headlight relay ?
There is no relay for the headlights (except DRL cars).
You're not supposed to get a ground there, you're supposed to get 12v.
With fuse removed and headlight switch on, you should get 12V+ on one side of the fuse socket and ground on the other side (indicates a circuit is completed through the switch, bulb and connectors).
