Old 08-22-2019, 12:05 PM   #11
EdPrem
Very unlikely indeed. But you'd be surprised how many people drive around not knowing one light has burned out until the second one goes and suddenly they have no lights.
In your case, since you've checked and found no power at the fuses, your problem seems to lie elsewhere. (Thanks, Capt. Obvious) My next guess would be your Low Beam Switch. That's what feeds fuses A9 and A10. Unless your car came equipped with Daytime Running lights. Then the DRL relay would also feed fuses A9 and A10.
Good luck.
I have replaced the switch and that didn’t work.
EdPrem is offline   Reply With Quote
