Old 08-22-2019, 08:41 AM   #12
piper6909
piper6909's Avatar
Originally Posted by EdPrem View Post
Right, both going out at the same time is unlikely. Additionally, no power leaving the 2 low beam fuses, so that means the bulbs are probably still good.
Very unlikely indeed. But you'd be surprised how many people drive around not knowing one light has burned out until the second one goes and suddenly they have no lights.
In your case, since you've checked and found no power at the fuses, your problem seems to lie elsewhere. (Thanks, Capt. Obvious) My next guess would be your Low Beam Switch. That's what feeds fuses A9 and A10. Unless your car came equipped with Daytime Running lights. Then the DRL relay would also feed fuses A9 and A10.
Good luck.
