Old 08-20-2019, 07:55 PM   #24
1PorscheBoxster986
A Porsche Guy
1PorscheBoxster986's Avatar
It sounds like you should replace the battery so good call. The battery is at least 6 years old and will fail over time. If you're using the cigarette battery adapter plug, you do not remove the positive and negative terminal cables off the battery. If you are pulling the battery out of the frunk and charging it out the battery tender via ring terminal harness or alligator clips then yes. You should remove the negative terminal first then remove the positive terminal. Vice versa when installing the new battery. You can always test the battery with a reliable voltmeter to see if it discharges a 14V range but I would just replace the old battery.
1PorscheBoxster986 is offline   Reply With Quote
