Old 10-06-2006, 05:46 PM   #6
CJ_Boxster
Send a message via MSN to CJ_Boxster
Still, The slave cyclindar doesnt sound right to me, How would you be able to hear the slave while its behind you, attached to the transmission????
I think theres a possiblity that whoever you took it to may have done unnessesary work to your car + lube your clutch pedal assembly,
Also, Sammy had the same issue with his pedal assembly and its a confirmed fix in his case.
Im not trying to bash you. Its hard for me to believe that i can hear the slave skean under the dash when its located on the transmission on the rear of the car outside of the passenger cabin.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
