Old 08-08-2019, 07:21 AM   #1
Starter986
1998 Boxster Silver/Red
Get a power bleeder, it will save you a ton of time
Unless your current fluid is dirty and dark, its a bit hard to see when the fresh fluid has pushed the old stuff out. You may end up using more than 1 liter
there was a post a long time ago the approximate amopunts needed to flush each caliper.
http://986forum.com/forums/performance-technical-chat/58952-brake-flush-amounts.html
And yes, Motul 600 is overkill for a street car. ATE-200 and Pentosin (Pep Boys has it) are good choices
Got the power bleeder, thank you. I've seen some members have attachments in-line... for ease of use. Would you recommend using it out of the box... or are there any fitting I can purchase fromn The Home Depot that makes the job easier?
In advance, thank you.
1998 Porsche Boxster
