Because of the tools required, I chickened out and took the car to Hans, my trusty mechanic. He swapped out the control arm in 40 minutes for $80. The part was $273.00 with shipping, so I got it fixed for 353.00.
Not cheap but not nearly the $880.00 my dealer quoted me last time it went out... 4 hour book rate @ $100 an hour and $480 for the part! Absurd.
Hans did use a special tool to break the ball joint free of the hub, and when putting it back on, he took a second floor jack and lifted the control arm up and bolted it in. (Insite, it did require him to turn the wheel a little and wrestle it to get it to go into place properly.) You can tell he's done it a hundred times or more.
I noticed this job requires two sets of the same sized wrench... so buying all the wrenches needed to get it done right plus that tool makes it an expensive learning experience.
On the way home, I drove it nice and hard to enjoy my newfound HP and torque and lovely exhaust note, something I have not felt the freedom to do with a worn control arm squeaking as loudly as the radio at times.
Hans says he did not move anything that would require me to get an alignment. Should I do it anyway just to be safe?
