Old 07-29-2019, 03:13 PM   #2
Qingdao
Qingdao's Avatar
I know you wrote that you already replaced them, and I know its a pita to change them out... But CV axles are like the only thing I could think of.
I've never heard of a motor mount causing of vibration under accel. If the mount is bad under accel it's settled in and not shaking.
Also, never had a wheel balance issue caused by acceleration only. Those things worsen with speed. Same with a wheel bearing.
The cutch/flywheel might be, but I doubt it. Just because that would give the car a shake under an engine rev and not just acceleration.
Completely different engine and water pump design, but RX7 engines will shake on accel if the water pump is bad. They shake badly enough to make me think the drive shaft was out of balance.
'98 PP13B powered "RX986"
Qingdao is offline   Reply With Quote
