Its not an expensive or difficult task to do on ones own. You need to lay on your back and look under the dash at the clutch pedal assembly, theres an adjustment screw and a lock nut, loosen the lock nut and adjust the adjustment screw, then tighten the lock nut and give it a road test....continue to adjust until it feels good to you...
Make sure you dont make it engauge too low cause you can grind your gears if the pressure plate isnt fully disengauged from the clutch disc.
