Old 07-19-2019, 11:43 AM   #12
Rupesy
I wanted to add two other things. When I start the car cold, it will idle perfectly at around 1000 rpm and after a minute or two (assuming the car goes to closed loop) the rough idle starts.
Also my rough idle stops and the car runs great if I rev it or keep the rpms high which would indicate that the actuator is stuck in advance. After taking off from stop, I can run through the gears no problem.
Rupesy is offline   Reply With Quote
