Old 07-13-2019, 04:59 PM   #2
hockenheim
The middle photo... the part that has stamped on it "AMP" and then some numbers. It appears to be a clip that you could remove with a flat head. Almost looks like it's channeled and you could slide it off. I'm guessing.
If you can remove that "AMP" part it app-ears the piece with wires would just pop out.
Could be incorrect. Trying to help. Best of luck.
You are spot-on . I initially thought the enclosure was a monolithic part but no, a flat-blade screwdriver will slide the cover up (i.e. toward the wiring harness side) and then the connector can be removed. Clever - almost too clever for me .
Also kudos to the seller of the seat belt receptacle - I forgot his handle but I think it is David (Freswick?). He replied to my text asking for help within minutes, notwithstanding the fact that I purchased the part a few weeks ago and only now got around to installing it. Love this community.
--alex--
Life's too short to drive cars you don't love
hockenheim is offline   Reply With Quote
