Old 07-03-2019, 01:23 PM   #1
Turbodad
SLide a 15mm open end wrench behind the pulley there is a nut. Crank the nut on the fron with a 24mm socket. it will tighten up the nutand the pulley will move normally. I did this just last week.
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
Turbodad is offline   Reply With Quote
