Old 06-27-2019, 09:17 PM   #1
Pretzel
There could be something that got wedged under the shift mechanism.
Coins get in there very easy. after checking cables to trans then try moving levers on transmission by hand if no movement then remove console look for anything that could be jambing the shifter. There are lots plastic parts to the shifter mechanism look for broken parts. let us know what you find
Sorry for the delay, but I was able to get in there last weekend and fix the problem.
I found a couple threads from the past describing what sounded like a similar issue, and it turned out my issue was identical. The best post I found, which even included pictures, was here: Has anyone repaired a Boxster shifter cable? - Pelican Parts Forums
Near where the shift cables attach to the transmission, there are some brass sleeves that fit between the outer and inner sheath of the shift cable. The sleeves appear to be placed to reinforce the shift cable in the spot where it passes through the bracket, where the bracket aligns it to properly attach to the transmission.
The brass sleeve is usually crimped into place, so that it sits in position where the shift cable passes through the bracket. The crimps can come loose, however, and if the brass sleeve slides towards the transmission's shift arms it can cause problems. Once the sleeve pops all the way behind the bracket, it will block the shift arm on the transmission from traveling forwards and consequently prevent the shift cable from being pulled towards the front of the car.
This is why my shifter and transmission were stuck in 5th gear. With the sleeve popped out of place, the shift arm on the transmission couldn't move forwards and I couldn't pull back on the shift knob. The brass sleeve was just getting jammed up between the transmission's shift arm and the bracket that aligns the shift cables.
To fix the problem I just slid the brass sleeve back into position and placed a hose clamp over the detent where it was previously crimped, tightening it until the sleeve stayed put. I've driven it for almost a week since that day with no further issues, so it was definitely just that one small brass sleeve on the shift cable causing all the problems.
Pretzel is offline   Reply With Quote
