Thread: Camshaft Codes
Old 06-26-2019, 01:25 AM   #1
shacky
Shacky
So the codes are for camshaft position sensor on both banks.
First: Were either one or both of these codes present before you took the car in for the recent work??
If not::
Then because both sensors are throwing codes after work has been done, I would be looking for something common to both sensors. wiring or a wiring connection common to both sensors may have been disturbed when the recent work was done.
Wiring may look ok but be to close to spark plug coils or some other electrical component that is causing the cam position sensor signal to be disrupted.
No the only code before work was done was fuel sensor. Also the top is now not working!!!
shacky is offline   Reply With Quote
