Old 06-24-2019, 05:51 AM   #21
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by Box7774 View Post
Ok will do.......I am pretty sure both windows do go down when I go to lower the top....so I assumed that feature was working for when I put the top back up. I will read up and figure it out....thanks
need to replace regulator, 95%.
The window drops slightly when you open door, shuts when closed. The regulator wears and doesn't suck the window down consistently. you can.confirm by pressing down on window when door open and the window is sitting too high for frame, if it moves a little, regulator.
