Old 06-22-2019, 05:18 AM   #10
itsnotanova
Originally Posted by rexcramer View Post
Another WAG. So that doesn't look like a scratch to me. It looks like the window tint is wrinkled/failing? And there are some small bubbles on the bottom left end? I think the grinding noise might be a separate issue from a failing regulator?
Cause might be something stuck between the door rubber and the glass? Although raising/lowering the glass would/should make a vertical line, not curved.
Try peeling the tint off first and see what shape the glass is in underneath.
X2. Does your window drop when you open the door?
Woody
