Thread: Things to check
Old 06-15-2019, 07:31 AM   #1
blue62
Originally Posted by pahanorlando View Post
Thanks do you use OEM mount replacement?
I just replaced the center part.
It has to be pressed in so you will need access to a hydraulic press. If you go that route.
The OEM part is the entire mount and is around $175.00 the center part is around $20.00-$40.00
depending on brand. replace the rubber side buffers also. They are around $15.00
If you look at the parts you will see what I am referring to.
