Old 06-14-2019, 10:24 AM   #1
Geir Nordvik
Geir Nordvik's Avatar
Cab adjustment again
Sorry if this has been a topic before.
While I am waiting for some parts; i was thinking that it could be good to have the top and the clamshell in a better working order. After a lot of fidling with arm lenghts; I have given up to get the perfect aligment of the top and camshell. I have not found an solution where both the top and clamshell are in end position. If the top matches the windsheld, the clamshell will not go flush with lid..
So, I have taken of the parts for the electric movement and will go manual operation until winter storage.
Does still have a problem to get the clamshell flush in passenger side. Seems like the top are to high or to close to the clamshell. I have tried to adjust the screw that holds the wire under, but not sure if it is adjusting the height. Could be that the wire simply are stretched, so that the top gets to high and pushes the clamshell up.
Any hints to get the top more forward or lower would be toppers.
Geir Nordvik is offline   Reply With Quote
